Inquisitive user
randy_k's Avatar
Fuel Tank Cap, I give.
Bought a new fuel tank cap with the tether to replace the none original one on the car, with no tether. I cannot however find where a hole is to insert the pin into to hold the tether in place is.
Pic below of fuel filler opening. Any ideas before I drill my own hole?
Randy
Perpetual change. It will happen!!!
Old 11-25-2011, 02:10 PM
Did the new fuel cap come with two tethers? Ive just bought the Alu cap and it was supplied with two, the one you show and a longer one. If your car is the same as mine you don't have a mounting point. What I ended up doing was mounting the other longer tether to the bolt to the left of your finger.
Old 11-25-2011, 02:20 PM
Inquisitive user
randy_k's Avatar
It only came with the one tether. But it would be long enough to mount to that bolt. My fear was. Pulling that bolt out and losening something underneath it that would fall to who knows where. LOL
Thanks for the help, Randy
Old 11-25-2011, 02:25 PM
Inquisitive user
randy_k's Avatar
And done. Why it needs a 10mm bolt to hold it in, I have no idea. But it works. Took 5 minutes.
Randy
Old 11-25-2011, 03:02 PM
JFP in PA's Avatar
If you look at the tank hatch hinge on the right of your photo, the lanyard is supposed to go into a small hole at the lower end of the hinge...............
Accrochez-vous bien de vos rêves..........."
Old 11-25-2011, 03:47 PM
Inquisitive user
randy_k's Avatar
JFP, If you mean that hole that is in the center between the two hinge sides? It is way to big. The grasping end of the pin slides right in and right out as well. At least for the pin that Wayne has on his site. No knock to Wayne. Just the facts.
Old 11-25-2011, 03:59 PM
JFP in PA's Avatar
No, all the way down the bottom, about "5PM" in your photo......below where the black plastic ends.
I have three cars in the shop with lanyard caps, that is where all of them attach.
Old 11-25-2011, 04:13 PM
ronster's Avatar
Randy
Nope, goes in the hole at the bottom of the door hinge, at least that's where mine fit perfectly and if it's an OEM cap there shouldn't be a difference.
Old 11-25-2011, 04:53 PM
Inquisitive user
randy_k's Avatar
Sorry guys, There is no hole at the bottom of the door hinge. There is a square hole in the hinge point mount itself. But again to big for the pin. There is an indention in the bracket that holds the door to the car. But no hole... The hole beneath the hinge is to big and the other hole is the one in the black plastic below the cap that appears to me to be a drain the way the plastic is shaped there. The only other thing is the indention that is below it, that may have been a hole at one time? But got filled and painted during the repaint, where the exterior of the body folds over into the bottom of the filler opening.
Old 11-25-2011, 06:09 PM
JFP in PA's Avatar
If you ignore the rag stuffed into the filler neck, this is how the tether mounts. As I remember Randy, you drive a 99, which would not have had one (they started in 2000-2001):
Old 11-25-2011, 06:48 PM
Inquisitive user
randy_k's Avatar
Yep a 1999, which would explain the fact there isn't one. But odly enough. That is exactly where I thought about drilling one and still may. Thanks JFP.
Randy
Old 11-25-2011, 09:16 PM
Inquisitive user
randy_k's Avatar
And done. 7/32 drill bit after stepping up from smaller ones. But everything fits well and I don't have to chase the fuel cap across the parking lot, when the wind blows 50 mph here. Thanks for the pic JFP. And everyone else for there input as well.
Randy
Old 11-25-2011, 10:09 PM
Alphaboy1's Avatar
Mine was also not connected and PIN was missing. All fixed now.
Regards
Paul
Old 11-26-2011, 04:45 AM
KCinBR's Avatar
And mine is just broke......hate to but the whole cap just for the tether.
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 11-26-2011, 04:53 AM
JFP in PA's Avatar
You cannot get the tether off the cap, plus the entire unit is not that expensive to begin with.
Old 11-26-2011, 05:28 AM
ronster's Avatar
Don't have an explanation as to why yours didn't fit in this hole but mine fit perfectly and I didn't have to drill any holes. Whatever gets the job done.
Old 11-26-2011, 07:52 AM
Inquisitive user
randy_k's Avatar
KC, Like JFP said. The cap and tether were only a little over 20 bucks shipped from Pelican. I replaced mine as the after market one tripped the CEL. And I have an emissions test coming up.
Ronster, That was my first thought, hole wise. But the pin was way to small for it to lock into it.
Anyway, It looks stock and it's done.
Thanks again for everyones adivce.
Randy
Old 11-26-2011, 08:17 AM
As a side note, there is enough flex to get the tether ring off and on the cap if you are being really cheap
If you don't live life on the edge, you take up too much space.
Old 11-26-2011, 09:51 AM
Alphaboy1's Avatar
JFP... Your Cap is in English.. Is that an after market cap?
Regards
Paul
Old 11-28-2011, 12:19 PM
JFP in PA's Avatar
Don't know, the photograph is not mine, I found it while searching for a shot that showed the lanyard attachment point.
Old 11-28-2011, 01:56 PM
