John Bosmans
John99Boxster's Avatar
Misfire, Cylinder 4
Had a CEL with a code of Misfire on Cylinder 4. Replaced the Spark Plug, Tube and Connector. Still misfiring at higher gears when I "punch it".
What else could it be? The Coil itself? The Wires?
What would you do?
Old 11-14-2011, 01:51 PM
nosnow4pc's Avatar
Probably the coil, you could do the poor mans test and change the coil to a different cylinder to see if the new cylinder gets a misfire. Then you'll know it is the coil and not something else.
99 Boxster 5-speed
12 Acura TSX 6-speed
Old 11-15-2011, 08:03 AM
John Bosmans
Problem Solved! Cracked coil replaced.
Runs great....NO CEL...no stumbling.
Old 11-16-2011, 11:34 AM
