01986320s (guest)
Guest
Posts: n/a
Wayne, I just ordered the L&N thermostat for a 2001 986S from Pelican today, and have one question. If I remove the OEM thermostat while the car is on ramps, can I just reuse what coolant drains out, or do I also have to perge the system of air also? thanks for any additional information.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Water Pump & Boxster Thermostat Replacement - 986 / 987
Old 11-17-2011, 12:58 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes and yes - you should be able to reuse coolant, but you will still have to go through the coolant bleeding process that is documented in the coolant flush article in our tech articles section here.
- Wayne
I have just completed this project in my 986 2001S.
I chose to re use the old coolant.
By doing this, I knew that what came out, must fit back in. So no guess work as to whether everything is OK before you lock it all up.
I did however spill some, maybe 1ltr, and the reservoir is now full without that 1ltr.
Old 11-17-2011, 09:24 PM
