2001 Boxter S
support bars
Hello guys.
Over the weekend, I removed the support bars and the pan cover, in order to service the transmission. I put aside the 2 nuts and 2 bolts of the pan, and started removing the other nuts of the support bars. When I wanted to put every thing back I found I have 2 nuts that are a little bit smaller in their external diameter then the others. Can you tell where they suppose to go? I market each one in a circle with a different color. ![]() thanks. |
