2003 Boxster S with Dead radio with blinking LED
A few days ago I lowered the faceplate on my CDR220 and after that the radio will
not come on. No previous problem with radio or plate. Fuse in main fusebox (D8..amp) is fine. Unhooked battery, hoping to reset and then punch in radio code....no joy there either. Pulled the radio to check for in line fuse but found none, all wire plugs in place. I'm out of ideas her and could use some advice. BTW... car also has the double beep intermittently upon lock/unlock. And is not currently beeping. Thanks Rick |
Author of "101 Projects"
I'm guessing a fault possibly with the ignition switch. It has constant power, as per the blinking red, but the on/off power seems to be corrupt?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne,
Happy New Year. Thanks for reply. Car starts and runs fine, all locks work, all key functions fine. Passenger side window does not inch down when door is opened. And double horn beep when locking/unlocking doors comes and goes. Don't understand looking to ignition switch for radio problem. What is interlink? Rick |
Update: took time to read radio manual cover to cover... duh.
Found that fuse is 10amp and not in line but right next to plugset. Pulled radio again, tested fuse (good) and pushed all the plugs back in firmly to assure seating. Put radio back in slot and keyed ignition.... voila... radio asking for codes. So far so good. Did pull faceplate again to look for CD slot near cassette but no find (does it exist???) and radio went dead again...,Hmmmmm.... wiggled and pushed seated faceplate and "its alive" I think its time to gently clean faceplate contacts. |
