Engine replacement question
Hello,
I've found a 2003 Boxter S I'm looking into and it had its engine replaced in 2005. How can I research what it was replaced with? If it was a 2005 engine wouldn't it be the type of engine where you have to completely disassemble the engine for a IMS bearing? Thanks |
Sometime in 2005, Porsche switched all engines over to the "final solution" style IMS that requires total disassembly to update. Unfortunately, the only way to know which cars/engines have this style bearing it to look at them; if they have the 22MM center bolt, you cannot update them.
There is no other known way (e.g.: serial numbers, dates of manufacture, etc.) to determine what you are dealing with. |
| All times are GMT -8. The time now is 12:56 PM. |
