Check Engine and Air bag
My check engine and air bag lights came on simultaneously this week and I'm wondering if any one else has had this happen. it happened after I replaced the 2 pre catalytic convert O2 sensors and the fuel filter. after the replacements were in place the car ran like a dream and still does but this warning light wont go away..any ideas?
Thanks, Mark |
the engine light might have something to do with your o2 sensor change but without a code we would be clueless, same with the air bag. find someone with durametric or piwis and get the codes. let us know
Crazy Austrian http://www.ws-ab.com |
Im meeting a buddy for lunch on Monday and she has a standard ODB reader so it might only read my fuel system but it's a start.. do you know what an average charge would be or where to go to get it hooked up to a durametric or piwis?
Thanks, Mark |
depends on your area. dealers usually charge around $90 some do it free. look for and indipendent Porsche repair shop in your area. If you post your area someone will most likely chime in and give you choices
good advice, thank you ' )
I live in Calgary, Alberta |
