Durametric & Alarm module analysis
G'day all,
I've disconnected battery -ve terminal on battery to remove seat to follow maintenance manuals alarm troubleshooting. One step reqs checking for battery voltage from one pin to a ground point. Does that mean I have to reconnect the battery so I can check for voltage? Is that a prob ref airbags? Thanks in advance |
Took it to the nice guys at NinePlus. Turned out the key head circuit board was failing (corrosion?). Bit the bullet with a new key & reprogramming, all works OK. Using the faulty key on the door lock was triggering the 59 code. No more reoccurrences!
| All times are GMT -8. The time now is 05:07 AM. |
