What warning is "limit 10" inside circle?
08 Boxster with Tip.
Put new tires on recently. Had two pressure sensor fail (supposedly). Finally got them to read. Now I have a warning after every stop of "limit 10" inside of a circle on the instrument face?
Any ideas?
Dana
Old 07-30-2012, 05:13 PM
one of gods prototypes
bell's Avatar
Iirc there is a setting which you can set in the cluster to chime at you if you hit a certain speed......sounds like that......
Use the menu selector switch on the steering column syalk and raise the limit and see if that's it...
Brought to you by Carl's Jr.
Old 07-30-2012, 05:22 PM
Thanks bell.
Just figured it out. I deactivated it.
Old 07-30-2012, 05:52 PM
Author of "101 Projects"
Wayne 962's Avatar
This has got to be one of the most commonly asked questions. On the early cars, the thing just chimes at you with no display, so people keep wondering what that's for. Some people take years to figure it out!
-Wayne
Old 07-30-2012, 08:23 PM
