pcmpete's Avatar
Engine dies when coming to a stop????
My 2001 Boxster 2.7 stick shift has started a random problem.
Coming up to a stop or red light the light engine would just die and the dash lights come on. Engine starts again first time and no engine check light.
I recently replaced a bad AOS and the burning oil stops coming up approx 100 miles ago.
Could the MAF be dirty?
Any help would be most helpful...
Pete
Old 09-08-2012, 10:33 PM
bar10dah's Avatar
You said there wasn't a check engine light, but I'd still check it for codes. You could have a pending DTC.
Has this stalling when slowing to a stop been happening since the AOS swap 100 miles ago? Or did this just recently start?
Old 09-09-2012, 03:30 PM
pcmpete's Avatar
It was trip out since the aos replacement. I took it for a long drive to burn the oil off from bad aos change.
Old 09-09-2012, 05:38 PM
Did you clean out the air intake, clean the MAF and clean the throttle body as part of the AOS swap?
Old 09-10-2012, 06:19 AM
pcmpete's Avatar
I cleaned the hose between the aos and the intake.
What is the best way to clean the maf?
Old 09-10-2012, 09:07 PM
Throttle Body Cleaning is covered at Pedro's Garage
MAF Cleaning here
Old 09-11-2012, 06:08 AM
