It'll be legen-waitforit
stealthn's Avatar
Winter Cayman storage
For those of us in winter places, what's everyone do for storing the Cayman? I am wondering whether to get a battery charger or just pull out the battery.
And yes I will use Stabl
Thanks in advance
Bob
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 10-07-2012, 07:33 AM
JFP in PA's Avatar
Normal prep: wash and clean car and interior, change oil and filter, fill gas tank and add Stabil, run for a bit to circulate, inflate tires a bit over normal, plug a battery maintainer (not a charger) into the lighter socket, lock car and set alarm, cover the car and let it sleep unmolested until the flowers are in bloom............
Accrochez-vous bien de vos rκves..........."
Old 10-07-2012, 10:21 AM
stealthn's Avatar
thank, yes that's what I meant. What type are people using, I saw one at the dealer but the price was stupid.
So do you have to leave a window open to run the power?
Bob
Bob James
18 Macan GTS
Old 10-07-2012, 03:58 PM
Alphaboy1's Avatar
Bob,
I purchased the Porsche branded maintainer that plugs into lighter socket. The passenger door on Boxsters and Caymans have an opening on the door molding to allow the cable to enter the cabin.
I actually start my car and get it to temperature every 3 weeks or so.
Regards
Paul
Old 10-07-2012, 04:38 PM
derfo's Avatar
Cool
Bob
I purchased a CTEK charger. These have terminals that you can leave permanently fixed to the battery. When you connect up, the lead comes out under the front hood, no need for windows to be open. These chargers are designed to be left on the car for long periods. Mine was on from end of December to July. After that time I just took the cover off the car unhooked the charger and fired up, no problems at all.
"Im only a small Giraffe but I eat from the big trees"
Old 10-08-2012, 03:03 AM
JFP in PA's Avatar
Originally Posted by Alphaboy1 View Post
Bob,
Bad idea; this actually allows acids to form in the oil, breaking it down and causing other issues. Put it to bed and let it sleep until spring........
Old 10-08-2012, 03:38 AM
JFP in PA's Avatar
Ctek makes all kinds of adaptors, including one for the lighter socket, which make hook up or disconnect a snap. Ctek is also one of the few maintainers that has a battery desulfation step in every charger it makes.
Old 10-08-2012, 03:41 AM
s_wilwerding's Avatar
I bought a $15 Dewalt trickle charger at Menards that works just fine.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 10-08-2012, 05:42 AM
stealthn's Avatar
Just checked Ctek's site and they are only rated to -4F which isn't low enough. Battery Tender doesn't have their specs listed so I emailed them. Any others?
Bob James
18 Macan GTS
Old 10-08-2012, 11:37 AM
JFP in PA's Avatar
I think the issue is that the battery charging profile is temperature dependent, meaning that any given charge cycle profile has both upper and lower temperature limits where the current level and duration become less effective (batteries also can actually freeze if they get cold enough). The electronics in the unit itself are also temperature limited as well and may not function properly outside the stated range.
But the question has to be are both your battery and the Ctek unit going to see long duration time frames below -4F? We see negative temps where my shop is, and the inside temps of some unheated garages in the area are actually in the 20-30F range when the outside air temp is -5F. In these situations, the Ctek unit works fine.
If both the battery and the Ctek are going to see prolonged temps below its operating range, it is time to pull the battery and the Ctek and move them inside so they both will be happy…………… Otherwise, you are going to need some more specialized maintainer for very cold use.
Old 10-08-2012, 12:54 PM
Alphaboy1's Avatar
Hi JFP... I change my oil in the spring which is about every 1000 miles a year. Do you think it would be ok to continue this this and store car all winter without starting the car?
Regards
Paul
Old 10-08-2012, 01:13 PM
JFP in PA's Avatar
No, change the oil before putting the car away, and do not start it while stored (use a good quality maintainer). You will be fine.
Old 10-08-2012, 01:32 PM
stealthn's Avatar
I store my 911 battery inside, but would prefer to leave the cayman one in. Battery Tender just responded with temps of -20 to 120, somI think I will go with them.
Bob
Bob James
18 Macan GTS
Old 10-08-2012, 04:07 PM
Alphaboy1's Avatar
Guys...this is what I have been using. Works great here.
Porsche Dual Mode Battery Maintainer / Charger : Amazon.com : Automotive
Regards
Paul
Old 10-08-2012, 04:51 PM
I went with the simpler and cheaper (and yet still overpriced) Porsche battery tender last year.
Porsche Battery Maintainer : Amazon.com : Automotive
I'm in the Minneapolis area, and no problems whatsoever with the cold temps.
1999 Boxster
Old 10-09-2012, 08:26 AM
83 911 Production Cab #10
JJ 911SC's Avatar
I purchased a CTEK charger...
Bob
They go on sale from time to time at half price at CDN Tire.
You can even go on line and set an alert for it and when it will go on sale you will get an E-mail the day(s) before the sale.
Last time, I sent my wife to pick me one as soon as the store opened.
Who Will Live... Will See
Old 10-09-2012, 09:14 AM
JJ 911SC's Avatar
Originally Posted by JJ 911SC View Post
Bob
They go on sale from time to time at half price at CDN Tire....
CTEK 3300, $45 when its on sale:
Compact four-step, fully automatic charger for 12V batteries
Can be connected for months at a time - ideal for seasonal vehicles
Rain and splash-proof, can be used outdoors
Charges even drained batteries
Continues to work in cold temperatures
Maintenance pulse charging increases battery life and gives superb performance
Short circuit, reverse polarity protection and spark protection
Desulphation technology reverses effect of sulfation
Charges deep-cycle, lead-acid, AGM and gel cell batteries from 1.2Ah to 120Ah
Includes two different battery leads, one with clamps and one with eyelet terminals
Canadian Tire Warranty:
This product carries a 5 year exchange warranty redeemable at any Canadian Tire store.
Old 10-09-2012, 09:58 AM
stealthn's Avatar
Battery Tender says to hook up negative to frame rails or engine block, not sheetmetal. Is it ok to connect the negative lead to the negative post?
Bob James
18 Macan GTS
Old 11-02-2012, 06:42 AM
derfo's Avatar
Cool
Yes, like I said in my first post on this thread, they give you terminals that can be left permanently on the battery until next time you hook up.
Old 11-04-2012, 04:31 PM
anyone put their car up on jacks for winter storage?? i read in the owners manual that it's not a good idea............adverse effect on shocks. thanks
Old 11-06-2012, 09:09 AM
