Author of "101 Projects"
Wayne 962's Avatar
Boxster Project 78: Door Lock Mechanism / Door Handle
Anyone got any questions on Project 78 - Door Lock Mechanism / Door Handle for your 986 Boxster, 987 Boxster, Cayman, Carrera 996, or Carrera 997?
Here's a back link to the original article: Pelican Technical Article: 78-BODY-Door_Handle_and_Lock
-Wayne
Old 12-31-2009, 04:10 PM
I have the issue with the passenger window not getting down when using the handle. The window operates with no issues when operated with the up and down switch.
I have taken the inner panel down and i can hear the door handle switch "clicking" when operating the handle. Sounds the same on driver side but there is no functional issue there.
Can i test the switch for normal operation with a multimeter? What should it read in that case?
Is there a wire diagram available on the switch circuit?
Or can i simulate the switch operation with something else to verify that it is the switch that is causing the problem?
Thanks in advance!
Old 04-28-2013, 01:42 PM
