-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   986 Boxster S instrument cluster not working (http://forums.pelicanparts.com/showthread.php?t=756406)
johnw7884 06-17-2013 12:16 AM
I have got a problem with 986 Boxster S instrument cluster not working properly;
- the analog speedo and rev counter do not move, both gauges do not move at all
- mileage, etc. on the lcd screen at the bottom of speedo do not illuminate
All other instruments function normally; fuel gauge, indicators, etc. all ok.
I connected with Durametric, and I checked the following
- engine rpm shows (i.e., rpm signal comes from engine dme)
- in the activations menu, I can activate;
rpm --->8000 ok
speedometer ---> full speed ok
However, I cannot activate lcd screen all pixels, the lcd part stays entirely dark, nothing shows.
Please any ideas where to start diagnostics?
Cheers!
KevinH1990 06-18-2013 03:16 PM
I have a little experience with the clusters based on swapping a Carrera cluster into my car. I prepared a document with some notes and pictures. If you send me a PM with your e-mail address, I'll forward it to you.
I don't have any experience with the problem you are experiencing. Have you removed the cluster for any reason such as to replace a light bulb? If you removed it, perhaps you did not seat one of the connectors correctly when you reinstalled it. If this sounds like a possibility, I suggest you remove and reinstall it. Wayne has published some good instructions here: Pelican Technical Article: Boxster 996 Gauge Cluster Upgrade - 986 Boxster (1997-04) -
If it was just one lcd not illuminating, I would suspect a failed bulb, but it seems like a big coincidence that all of them would burn out at the same time. Perhaps there is a fuse that powers part of the cluster that is out. I think you need to check B1, B10 (both 15 amp), and E1 (7.5 amp). However, since you have a car built for Sweden your fuse layout may be different. So check the chart under your fuse cover.
Another remote possibility is a fault with your ignition switch.
Good luck with trouble shooting.
huntern321 08-23-2016 11:04 AM
Was this problem ever resolved? I have almost exactly the same problem at the moment with my 986.
Dino6137 03-18-2020 08:49 AM
Mr rev counter is completely erratic and has a mind of its own. I have been told the coil packs breaking down could cause this, any hep would be appreciated. Dean
Dino6137 03-18-2020 08:50 AM
Sorry I should have said its a 2000 996 Boxster 2.7 And the car runs fine no issues and the OBD has no faults found...
