Guest
Posts: n/a
My 1998 Boxster is throwing to codes: P1124 & P1126 in addition to a low output reading from my MAS. Reading on the two codes indicated that it could be an AOS issue. My questions is: if the AOS is an issue, could this also be fouling up the sensors on the MAS? Thanks.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
There would have to be quite a bit oil to reach the MAF sensor. It would have to work up theintake pipe, against pressure. I would guess not, but you never know. If you knwo the AOS is an issue, start there and see if your codes are rememdied.
- Nick |
