-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   What is this Boxster worth? (http://forums.pelicanparts.com/showthread.php?t=765052)
Ira 08-08-2013 06:36 PM
Posted this on Rennlist with no replies. 1999 Boxster 143,000 miles is white on tan, tiptronic, oil leak substanstial, chain tensioners noisy on start up and needs a right rear shock. Drives good. body and wheels look good. Oil leak location has not been identified. After sitting puddle is abou 6" in diameter. Thanks
JFP in PA 08-09-2013 06:28 AM
Not a lot; the oil leak is probably the RMS, so you are looking at $2-3K to pull the Tip, update the IMS and RMS, throw in a new AOS while the Tip is out because it is out in the open at the time. Add in a set of new chain tensioners at a minimum (the car may need the chain paddles as well because the early ones wear more quickly, which will add a substantially larger amount to the repairs tab) and you could be in the $5K range to fix everything.
If you can get the car a the right price, it might be worth doing, but you need to think about what you are going to spend immediately just to put it on the road......
Ira 08-09-2013 07:13 AM
Thanks for the insight, I'm going to let this one go unless of course the price is right. Thanks again.
