Guest
Posts: n/a
I have an '01 Boxster with 147,000 miles. The brake lights have started flickering when I depress the brake petal. They either flicker or they don't come on at all. Any suggestions what or where the problem might be? Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Check the brake switch and the grounds for the lights. Do the other lights flicker when you turn them on
- Kerry |
It's probably a bad switch. Mine was a bear to get to. You have to be a contortionist to get it out. I gave up, and took it to the dealer to the tune of $145.00, including a new switch. BTW, with that many miles, are you still on the original IMS?
