mike (guest)
Guest
Posts: n/a
I have a 2000 boxster and after it was serviced, "with the battery disconnscted" I shut the passenger door. I did not realize the window had not lowered itself. I tried several times to close the door with the window up not knowing it was all the way up. When I realized the window was all the way up I lowered the window manually with the window switch and closed the door. I guess I broke something when I kept trying to close the door with the window up. Now when you pull the inner or outer door handle the window lowers part way but not enough to open the door. The window will raise and lower with the regular window control switch. There is a pop when the window get all the way up. Any ideas what I broke
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-29-2013, 06:25 AM
Nick at Pelican Parts's Avatar
First be sure your windows are properly initialized. Hold the window open button until window is rasied and hold for 5 seconds.
- Nick
