Guest
Posts: n/a
My car started to overheat so I replaced the thermostat and water pump. After I got it back together and fluid back in, I warmed it and took it for a short spin. As soon as it got up to 180 deg. the temp started to shoot up. I checked under the car and fluid was pouring out df the overflow. What else could be causing the fluid not to flow through the system?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
You could have air trapped in the cooling system. First be sure it is properly bled. If it is and still goes to the red when driven, you may have a faulty head gasket.
- Nick |
