How to test cut-off valve
This is the cut-off valve of the secondary air injection system. I suspect it is malfunctioning and that is why my AOS is about to give up (replaced 7K miles ago).
2003 Boxster, 2.7H - AOS soon to be replaced twice in a year (see next) - smoke at start up with increasing frequency, say 2 out of 10 times. It goes away after a few seconds - I did find oil in the vent hose of the AOS and in intake manifold so the AOS is toasted but I do not believe replacing it is enough, the problem is coming from somewhere else and I suspect a stuck cut-off valve. Questions 1) is the cut off valve open or close when the engine is off? I try blowing in it and it is definitely close 2) how do I test if it is working? Thanks!!! BUMP: added the poll, cool idea, I did not know we had it! |
| All times are GMT -8. The time now is 03:37 PM. |
