Clutch
Need help. Driving today and the clutch went to the floor and now has no pressure. It seems like a broken cable, but no cables on a boxster. Any suggestions? Thanks for the help.
Old 01-06-2014, 10:34 AM
leaking?
I'm guessing hydraulics. Notice any leaks?
Pelican Technical Article: Boxster Clutch Hydraulics Overhaul (Boxster Master Cylinder & Boxster Slave Cylinder Replacement) - 986 / 987
Old 01-08-2014, 03:20 PM
Turd's Avatar
Happened to me last summer. Clutch/brake fluid gushed out underneath car at same time. Nothing you can do but tow it to where you are going to fix it. Mine was a break in a hydraulic line that got rubbed on a BC car ferry ramp.
Old 01-09-2014, 04:03 PM
happened to me as well, hydraulic fluid was seeping out of the bottom of the transmission. To make a long story short the clutch arm broke allowing the slave to overextend and pop the piston out and release fluid. I had to remove the gearbox to replace the clutch arm, and while I was in there did the usual, clutch, RMS, IMS, etc.
good luck
Old 01-22-2014, 10:01 AM
This is my first post on this site so please inform me if I am approaching this the wrong way. I searched for this topic so this is where I ended up. Here's my question. Second time replacing the clutch, the first one went very smooth, no problems. I have two Boxters and when I had reassembled the Boxter S I decided to check the play on the clutch before firing it up and taking it off of the lift and the pedal went to the floor and stayed there. So, I guess I am pulling the tranny again to see the problem. The slave was in place and the tranny buttoned up so could there have been an alignment problem?
Old 01-22-2014, 09:41 PM
that would by my first suspision as well, i would just remove the slave without taking the whole thing apart to confirm the alignment
Old 01-26-2014, 01:33 PM
