Help with Air bag delete??
Hi there - recently installed new Corbeau racing seats in 01 Boxster S - how do I delete the airbag light ? Need to pass annual inspection (MA) and can't with airbag light on - surely this is a common problem, no?
Thanks, Michael |
help
seriously - over 100 people have read this post and no one has an answer or suggestions? Please someone, perhaps Pelican Parts?
Use Durametric to reset the light.
Resetting the light will not help, it will simply retrigger because the problem is still there. The car has to be modified so that it thinks the air bag is still connected, then reset the MIL.
You should also be aware that most shops will not help you with this modification due to the liability risk of disabling a Federally mandated safety system; DIY only.
Accrochez-vous bien de vos rêves..........." |
