Paul (guest)
Guest
Posts: n/a
Ok, I haven't seen this one yet. '02 Boxster S, drivers door. Inside or outside the winnow drops to clear the roof, so far so good. But, as soon as you release the door handle it pop right back up. It doesn't seem to realize that the door is still open. Then when you close the door the window is jammed outside the roof. The courtesy lights work normally and all the other systems get the word that the door is open. Which microswitch or relay would it be?
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-13-2014, 04:58 AM
Nick at Pelican Parts's Avatar
This issue is usually the door latch microswitch. Try cleaning the latch with WD40 then lubricating it.
- Nick
