Clutch Replacement - Flywheel Degree Wheel
Can anyone direct me to where I can download the flywheel degree wheel that Wayne uses to tighten the flywheel bolts and he says is available on the 101 projects website? Looks like a great tool for finishing up the flywheel bolts properly, but I can't locate it on the Pelican Parts or the 101 projects website. It would probably been a good idea to dedicate a page in the book with the picture.
By the way, the 101 projects for the Boxster is so good, that I bought the 996/997 book as well.
Thanks,
Old 08-04-2014, 10:11 AM
JFP in PA's Avatar
You want a torque angle tool, which looks like this:
It is a Lisle 28100 Torque Angle Meter, about $30 on Amazon.
Accrochez-vous bien de vos rêves..........."
Old 08-04-2014, 10:50 AM
Schnell Gelb
Suggest you avoid the no+name cheapo ones (Lisle is O.K. If JFP says so!)
The cheap ones have a built-in error because of the loose fit of the square drive. It means you may get 5 degrees of rotation just to remove the free-play.
I tried one of these. Yes they are expensive but I found it very accurate and convenient because it uses a sequence of different beeps as you approach,reach & exceed the per-determined angle.
Digital Angle Gauge & Digital Torque Wrench | Brown Line Metalworks
I have no idea if such accuracy is essential -others will perhaps know that?
2001 Boxster S
Engineers muse
Old 08-05-2014, 01:42 PM
