Guest
Posts: n/a
car stalls once at 179 degrees. then i easily restart. however engine rpm goes up 200 rpm and stays at 1000 rpm. engine exhaust tone changes a bit deeper. could this be a vac leak on right side purge valve flapper causing internal leak? if so how to fix and also do you have pary in stocks.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
We do have stuff in stock. Give our parts specialists a call at 1-888-280-7799. They can help you find the right part.
A hot stall is a bit of a weird one. I would want to see some engine data to make a call. What is desired and actual engine RPM when starting and up until the stall. What are the fuel trim values? - Nick |
