-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Question on Boxster Window Regulator (http://forums.pelicanparts.com/showthread.php?t=832529)
coveylane (guest) 10-03-2014 03:03 PM
Recently had battery die in 2006 Boxster. After recharge, everything seems to be working fine except drivers door window. It drops like it should but does not go back up in place once the door is closed and also the auto up for that door isn't working. all started after battery problem. Tried to initialize according to your directions With the convertible top fully closed, press the up button on each window and then continue pressing down for about five more seconds but that didn't help.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-03-2014 03:03 PM
This can be an issue with the door latch microswitch. Try cleaning and lubricating the door latch.
- Nick
dronz 10-04-2014 07:44 AM
i think i had the same problem after i changed the battery after 6 years . the battery was still working but i decided to change it cause didnt want to be suprised in winter. the window of the driver cause the same problem so i changed the mecansm and it works now. is there really a conection btw changing battery and the window machenism faillor i wonder?
bell 10-04-2014 08:11 AM
The 05 and up cars use a small plastic nipple on the interior door handle which sticks into a small hole right behind the door handle. .... This nipple presses a small plastic button to tell the window module that the lever is pulled which drops the window to open.
2 things happen here. ...the door handle isn't properly hitting the button, either the button (which is part of the window switch) is deformed, or the hinge plate for the handle is cracked and mis-aligning the handle.....
