oil leak
Can the valve/cam covers be replaced in the vehicle and if so are there any precautions/recommendations
oil leak
sorry, 2000 Boxster 3.2
On these engines the cam cover forms one half of the bearing for the cams. If you have a leak from the covers it could be a number of things. Spark plug tubes, they have seals, end caps (green) for the cams, seal on the cam solenoid, cam cover to head seal needs cleaning and resealing. Have a look at these areas. Try and clean the outside as much as possible, then you may find were the leak is coming from because you don't say in your post.
"Im only a small Giraffe but I eat from the big trees" |
