-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/showthread.php?t=835294)
Lance (guest) 10-22-2014 12:04 PM
Nick, I did not replace the O2 sensors when I did the exhaust. I am more concerned with a larger issue going on with the engine that is causing the O2 sensor to initiate a code. The car runs great, but the left exhaust will soot and not the right. Is this a sign of something going on in the left bank?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-22-2014 12:04 PM
The soot you see could be a product of a faulty o2 sensor or a larger fuel trim problem. I would need to see fuel trim at idle, 2500 rpm and at a steady cruise.
- Nick
