Battery for 2006 Boxster: Recommendations?
Hello All,
I have a 2006 Porsche Boxster. The battery, which came with the car, will no longer take a charge and needs to be replaced.
Any recommendations for a good value replacement for the battery?
Many thanks.
Old 10-28-2014, 03:48 AM
The battery is not a special part, just a battery. While I went the Optima route just because I wanted to try one, any battery of appropriate size and ampere hours power will do just fine (see owner's manual). Buy on availability, price, warranty.
For the 986, I once had around two dozen known to fit listed but never had a 987 so can't help with specifics. For the 986, the tiptronic car's battery was bigger than the manual trans version so look and see if that matters for your 987.
Old 10-28-2014, 08:34 AM
I just installed a Bosch #48 size in a customer's 2005 Box 5-speed. I believe a Tiptronic Box calls for a #94 size. If your battery will be subjected to neglect or subfreezing temps or you just don't care about the extra cost & weight get the larger size & upgrade to a AGM (absorbed glass mat) battery. I previously installed the Bosch #48 in the same customers BMW, so it seems to be a "European" premium size & are priced accordingly.
Old 10-28-2014, 10:01 AM
If I were shopping for a battery, I would find an Optima that fits - they don't list one for a 987, but I'm sure there's one that will fit in there. I've had 3 of them and they're absolutely fantastic batteries. No problems with them, and no maintenance. One was in a Toyota Tacoma, and 2 others are in constant use, hooked in series to power a 24V electric boat motor. Excellent durability.
Roger
'08 Boxster S, and over the years a few others. A daily driver 911SC, and a 356B... you guessed it - a Super 90!
Old 10-29-2014, 07:33 AM
