Mac (guest)
Guest
Posts: n/a
Hi there ! I have Todd Holyoaks 3.8 conversion 2001 Boxster. Has manual trans. I need to swap this into a 2001 tiptronic trans car circumstance of left and right hand drive cars here in Thailand No one has imported a manual shift as Thais like automatics, so I'm limited in local cars for sale and they all have tiptronic. What later tiptronic trans should I use,so it will hold the torque, hp, etc and will it bolt up and what brain will I need for it ? Thanks for your help...best, Mac
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-27-2014, 06:39 AM
Nick at Pelican Parts's Avatar
You should be able to use one from a 2004 or 2005. I would grab the lowest mileage one you can find. As far as the swap, you will need the DME and TCM at the minimum, plus the wiring harness.
- Nick
- Nick
Thanks much, Nick. I have my DME (7.8) with the 3.8 Carrera S motor. TCM will be from a 2004, so should work OK ? best, Mac
Old 12-27-2014, 08:05 AM
