cuco996 (guest)
Guest
Posts: n/a
I had some smoke huge clouds driving hard and at start ups on a boxster 986 S. I decided to change the AOS, because when I disconect the hose that conect the AOS whit the admision there was oil in there. After that, I drove for about 1000Km 600 miles and no more smoke clouds. This weekend on a hard left turn a huge smoke cloud apers. I have removed again the hose and there´s oil in there and on the intake. I´m guessing if the two oil separators inside the engine are broken. Any sugestion?
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-31-2015, 12:45 PM
Some cars require the use of a motorsport AOS when driven in extreme driving conditions. Double check to make sure the oil level is between minimum and maximum not a hair above MAX. I have also seen where some oil pools in the intake manifold tuning flap and comes out after driving the car hard. Could just be a matter of getting the remaining oil out of the intake and exhaust system over time and with extreme exhaust temperatures.
- Casey
