Guest
Posts: n/a
Hi, have just serviced my Porsche Boxster 1998, the Porsche mechanic has found an oil leak from the rear main seal area? Is that what they call the Gasket seals? Please let me know, or should I just ring the mechanic and ask him??
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
No, that is an oil seal around the crankshaft. The transmission will have to be removed to replace the rear main seal.
- Nick |
And while you are into that (and have paid for the trans Remove & Replace) consider an IMS, clutch and AOS replacement, all cheaper when the trans is out.
PCA Certified D.I.
WAIT, just how serious is the leak? Porsche designates a leak as a "constant flow" of fluid. Drips don't count.
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice" |
