Guest
Posts: n/a
I have a 1998 Boxster and the check engine light just came on. I scanned it and got codes: 1123 and 1125. I checked online and it looks like 2 of the O2 sensors. I just need to know if it is the two before or after the catalytic converter?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
1123 and 1125 are fuel trim fault codes, your car is running too rich. I would check the mass airflow reading with a scan tool. Should be 15-17 kg/h at idle warm with the a/c off. If it is too high, replace the mass airflow sensor. If it is in spec, check fuel pressure, it could be too high but that is VERY rare. This is most likely a fault with the mass airflow sensor.
- Casey |
