-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/showthread.php?t=894898)
Vox (guest) 12-14-2015 05:51 AM
I have very low oil pressure on my 2001 Boxster S with 155,000 miles. My mechanic replaced the oil pump and oil cooler but no change, he thinks there is a crank shaft bearing problem causing the oil pump not to function properly. Any advice? Is it a gonner?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987
Nick at Pelican Parts 12-14-2015 05:51 AM
Is there metal in the oil filter? If so, it may be too late.
- Nick
