I have a 99 Boxster with a tiptronic in and was wondering.
A. If i swapped to a larger later 986 3.2 engine what are the modifications i would have to do to the car other than the electronic throttle?
B. Will i need to swap transmissions or do any ecu programming in order to hook up the new engine to the tiptronic.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Engine Conversion Project - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 01-28-2016, 06:16 AM
Nick at Pelican Parts's Avatar
You will need the wiring harnesses and control modules to start. Then work through whatever faults there are as you get it going.
- Nick
