have a 2002 boxster base with 62000 miles. tiptronic. two questions: 1. IMS issues or no, and when? 2. starts in first gear, but when warm,, goes back only to second. might be hi torque or problem?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987 |
Your vehicle can have an IMS issue.
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing. - Nick |
| All times are GMT -8. The time now is 10:47 AM. |
