Guest
Posts: n/a
HI MY 2006 cayman s has a random misfire at idle runs fine does not use any oil, sometimes it has a misfire at idle sometimes it can idle great on the drive for extend-ended periods, random warning lights also come on and off, abs/pasm hand the coil packs changed did not improve, any advise. thnak you Paul
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987 |
Is the check engine light on? I would check spark, fuel and compression on all cylinders.
- Nick |
My Volvo V70 has been doing this. I have read that it could be a faulty fuel pressure check valve or fuel pump.
Only happens at startup and idle, mainly when ambient temperature is very warm and car has been in the sun. Might check fuel line pressure. |
