questions litronic boxster!
Good morning , I have a boxster the 2002,2,7cc and I'm going crazy with litronic headlamps ...
top left headlight after a while that it was on went out, he switched back from the switch and went back to work. I thought they were the bulbs , then replaced D2S lamps ( with two 8000k ) , replaced starter and replaced the control units (ballast )
for ten days all right , but now turns off the right headlight ( passenger) can last 10 minutes as 1 hour.
if the car is stationary work endlessly but just shortly after childbirth goes out , power back up and go back to work for 10 minutes .
I checked the headlight coupler, and is ok . I lubricated every contact and the switch on the dashboard , checked the wiring to cut any wires or stripped but nothing .
it seems that the lighthouse goes into protection! because if I leave the lights on, detachment and resubmit the lighthouse back to work!
What other controls do I do ?
what can be more ??
please give me help !!
Old 04-03-2016, 02:51 AM
Every 986 Boxster eventually requires a new light switch.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 04-03-2016, 02:11 PM
can that be? although only a lighthouse on two ?
I tried disconnecting the lighthouse while swich was entered and only one light off and unplugging and plugging the lighthouse worked! current there !
Old 04-03-2016, 04:25 PM
