With the tranny out, can I remove the cover from the IMS to inspect it without having to bring the motor to TDC and lock the cams since I don't have the tools.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Transmission Removal - 986 / 987 (1997-08) - Pelican Parts Technical Article |
No, once the cover is removed the tension on the chain will pull the shaft. It has to be locked down before removing.
- Nick |
Locked at tdc thru the nose pulley and the cam ends locked also. Do not use the flawed Pelican instructions which refer to locking the crank with bolts thru the crank flange
| All times are GMT -8. The time now is 07:03 AM. |
