Andrew (guest)
Guest
Posts: n/a
Greetings Pelican Staff...great service thanks.
I have a 1999 Boxster about 90K miles and while attempting to change the spark plugs noticed a lot of oil in the tube which holds the plugs bellows?. Is this due to a bad Air/Oil Separator? If not, can you advise?
Thanks again,
A. Oliver
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Air / Oil Separator Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 05-13-2016, 01:19 PM
Nick at Pelican Parts's Avatar
More likely the valve cover is leaking. I would replace the gaskets. Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
