artk (guest)
Guest
Posts: n/a
Hello Pelican! You doing great job with yr projects.
I am from Russia have no access to special tools. So I sould make my tools myself. I use drill to lock TDC and make cam lock for my boxster 99.
I lock engine in TDC and lock cams in back left corner, is it correct? Then loosen tensioners and remove cover of IMS.
I successfully make IMS remover and extract my old IMS bearing in good condition. But inside bearing I have a some engine oil and I want to replace it.
In this case I have tho questions:
1. IMS shaft is not centered. But in most photos it also not centered well. I think it is not big problem, then I reintall cover it centered shaft. I am right?
2. I cannot find replace bearing. Only NSK 6204 Sealed. But You in your project use same baer is not it? So I can made some precision spasers: one 47 mm out and one 20 mm in or I can disassemble one more bear and cut it:
Please help me to confirm my ideas- about center of shaft and about spasers
Sorry for my English, with best regards, artk
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06)
Old 05-19-2016, 02:21 PM
Nick at Pelican Parts's Avatar
The shaft not being centered is Ok, IF the tensioners are removed and the shaft is moving freely. it will have to be centered when you extract the bearing.
I don't have info on the bearing sizes. To be sure, Give our parts specialists a call at 1-310-626-8765
- Nick
Administrator
Luccia at Pelican Parts's Avatar
If you don't have access to specialty tools, we have them on our site which you can have shipped to you if needed:
Automotive Tools, Shop Tools, Hand Tools, Power Tools, Specialty Tools - Pelican Parts
Old 05-19-2016, 03:36 PM
