It'll be legen-waitforit
stealthn's Avatar
Cayman overheated on me today - Need help
First time ever, luckily I was right by a service station and pulled in and shutoff. I flat decked her home and am looking at the fans, but I can't see where in the Durametric software is the Fans activations.
Can someone please let me know what section these are in and what they are called?
As well, where are the relay and fuses for these as the docs in the fuse box don't have anything like fans.
Thanks in advance,
Bob
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 05-29-2016, 04:19 PM
stealthn's Avatar
Found it - it's under the "Front" section - Radiator fans.
Fans both worked in high and low and engine fan worked as well. I'll let it cool then check the fluid. Could be the thermostat....
Is there a durametric option to open the thermostat?
Anything else I should check?
Bob James
18 Macan GTS
Old 05-29-2016, 04:56 PM
How many miles? Could be water pump if fluid levels check o k
Tony G
2000 Boxster S
Old 05-30-2016, 06:01 PM
Cajundaddy's Avatar
Water pump is the most common cause of overheat in a 987. Mileage? Any recent work done? Were you driving or stuck in traffic?
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 05-30-2016, 06:06 PM
+1 on the water pump and thermostat. If you have a way to jack up the car and feel around on the hoses at the engine you can see if the coolant is circulating out of the thermostat. If the car is above normal operating temps the hoses should all feel equally hot to the touch. Cold hoses mean bad water pump and or thermostat.
Old 05-31-2016, 10:57 AM
stealthn's Avatar
Thanks guys, it has 83000km (50000 miles). Funny thing was I drove across the city with no issues, stopped for about 45 minutes, then headed back. It went hot in about 10 minutes of driving.
I haven't had a chance to look at it further but it's in the garage on jacks. If pump, would there be any indication like sound or problems with the drive belt?
The strange thing is I checked the coolant, and it's up to the top of the cap, much higher than where I filled it at the start of the year (up to the high mark). I did have new Bilstein's and a half shaft put on 3 weeks ago, but I doubt the dealer would have messed with the coolant system.
I've never seen signs of a leak, but I am suspecting an air bubble, but I don't know how it would have got in. My plan is to warm it up and feel the hoses at the rads to see if fluid is going forward, if not pump and thermostat, if so run it up in temp with Durametric hooked up to watch the temp. Any other thoughts?
Bob James
18 Macan GTS
Old 05-31-2016, 06:38 PM
The coolant levels in the tank fluctuates so I'm not sure that's the problem. If the cooling system hasn't been opened up, drained or refilled etc, then I doubt an air bubble. I think the rx for water pump change out is 60,000 miles, so it could be that or thermostat. If the serpentine belt broke then you have no circulation. Pull off the cover behind the seats and check that before you start it up. Could be that simple, albeit unusual.
Tony G
2000 Boxster S
Old 06-01-2016, 03:55 AM
stealthn's Avatar
Not the belt, I changed it ladt year, and checked it's fine.
I'll get it up to temp and see what's going on.
Bob James
18 Macan GTS
Old 06-02-2016, 08:36 PM
stealthn's Avatar
Alright I'm really confused now, I got a chance to work on the car and got it up to temp. I watched the fans come up and off as the car warmed up, then it got to 175 and just stayed there (normal). I put on the heat, AC, rev'd her up but it all seemed normal.
The strange part is the hoses to the rads never even got warm, so I don't know what's going on with that?
I think I'll have to do a few laps of my street to see what happens under load, but this is a strange one.
Bob James
18 Macan GTS
Old 06-07-2016, 01:57 PM
stealthn's Avatar
I don't know I assume there is only two hoses, feed and return, and both were cool.
Bob James
18 Macan GTS
Old 06-07-2016, 03:16 PM
Either way, if the car is at operating temp via the gauge the inlet hoses and outlet hoses should both be warm if the thermostat is open, and the pump is pumping.
Old 06-07-2016, 03:51 PM
Originally Posted by casey at pelican parts View Post
either way, if the car is at operating temp via the gauge the inlet hoses and outlet hoses should both be warm if the thermostat is open, and the pump is pumping.
+1
Tony G
2000 Boxster S
Old 06-08-2016, 05:40 AM
stealthn's Avatar
I've ordered a pump and thermostat kit from Pelican to hopefully correct the issue.
Bob James
18 Macan GTS
Old 06-09-2016, 02:18 PM
Stealthn, If you wouldn't mind comparing the pieces, possibly taking some pictures of the two pumps and thermostats side by side before installing that would be great! I am guessing that you might be able to see some sort of difference in the water pump impeller, or the thermostat. Your pictures might possibly help someone in a similar predicament.
Old 06-09-2016, 02:25 PM
stealthn's Avatar
Sure no problem; do I have to "bleed" the system or can I just refill the coolant after buttoning it up?
Bob James
18 Macan GTS
Old 06-09-2016, 02:29 PM
stealthn's Avatar
OK almost got everything together, thermostat, water pump, Airlift, anti-freeze, etc.
I got the car jacked up and had a look, the stupid undercarriage tray is a stupid design and was tricky to get off (this without a lift). Now I see the thermostat and see it's caked in dried coolant. Not sure if it's leaking down from the water pump, but going to change them both so I don't really care.
There is little to no room under the car to work so I'll jack up the read end a little more for the swaps, so I can work under it. Sure seems like the front of the engine is a long way in there when you're under the rear of the car
Will take pictures when I get everything out to compare
Bob James
18 Macan GTS
Old 06-20-2016, 07:12 PM
stealthn's Avatar
So I get under there and find Hex head sockets are required for the thermostat and regular sockets for the waterpump - wtf?
Off to the hardware store
Bob James
18 Macan GTS
Old 06-27-2016, 05:44 PM
stealthn's Avatar
OK phase 1 done, I got the pump and thermo off; what a job! especially without a lift and only a foot of clearance. The pump impellers look fine so that's good but it was leaking out the shaft in the front. I will assume it was the culprit.
Here are pictures of the pumps - old and new, the front of the old one and the old and new thermostats
I'll button everything up tomorrow and then I get to try out my new Airlift so I can pressure test and fill the system with no bleeding.
Bob James
18 Macan GTS
Old 07-02-2016, 02:47 PM
stealthn's Avatar
Still have an issue, trying to use an Airlift system to get vacuum and fill the coolant, problem is I can't get vacuum. I've verified I tightened all the hoses I was working on, pump and thermostat, and verified the Airlift is sucking vaccum but I can't get any vacuum.
Is there an overflow line for the 06 Cayman or is it completely closed system?
I even bought a new compressor thinking my little one does not have enough CFM, but same deal.
Thoughts?
Bob James
18 Macan GTS
Old 07-24-2016, 08:56 PM
Oh yeah, forgot about that. On the Cayman you have to pull the vacuum from inside the engine compartment, not at the coolant lid in the rear luggage compartment. Open the engine lid, and to the right side you will see a coolant reservoir. Remove the cap there, and i believe you have to pinch off a vent line that goes to the filler neck, then pull the vacuum from the coolant reservoir inside the engine compartment.
Old 07-25-2016, 06:45 AM
