Passenger side radiator fan won't turn off
Got home from a short trip (3) miles. Radiator fan was working when I parked in my garage. Turned off the key and it was still running. About 1/2 hour later I returned to the garage and it was still running. Engine temp was normal during the drive.
I had to disconnect the battery to keep it from discharging.
Any help will be appreciated as to why it won't turn off.
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 08-04-2016, 03:33 AM
I'm thinking it's a bad relay. The Porsche/VW/Audi part number is 141951253B Later this morning, I'll head over to my local electronics supply house and buy 2, one for the high and one for the low fan settings. Hopefully that will solve the problem. They're only $7.99 ea so hopefully it may be a cheap fix. They are just a 4 prong relay available at most electronic shops
Old 08-04-2016, 06:36 AM
The new relays solved the problem
Old 08-04-2016, 12:28 PM
B85 B85 is offline
B85's Avatar
Good job !
Old 08-04-2016, 03:20 PM
