-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/showthread.php?t=924311)
Charlie (guest) 08-05-2016 06:20 AM
I have a 1999 Porsche Boxster, starts fine runs fine, but after a while running it stalls, trans goes to 3rd and engine comes back to live while diving. Any info would be appreciated. Thank you In advance.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987
Nick at Pelican Parts 08-05-2016 06:20 AM
This could be from a power issue to the DME, possible ignition switch. You can confirm this by monitoring battery voltage to the coils when the problem occurs.
- Nick
