-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Dirvers Side Window (http://forums.pelicanparts.com/showthread.php?t=93204)
Mark Griffin 01-06-2003 06:23 AM
Dirvers Side Window
I got a problem with my drivers side window! As I got in my car this morning I had trouble shutting the door, Which was nice as it was snowing and bloody freezing.
What the problem is that the window normally moves down slightly as you open the door and up again as you close it, this is not happening. Also the window is not opening and closing at all. I can hear something (maybe the motor) in the door as I press the button. Has anyone got any ideas of what the problem could be. If so any tips on how to fix it.
Mant Thanks
Mark Griffin, Brighton, England
rfoulds 01-06-2003 07:41 AM
If you are definitely hearing the motor when you press the button or lift the door handle but the window does not move, then the lift arm has disengaged.
If the window is so lose that it wants to drop down into the door by itself, then it has slipped off the tracks.
Its more likely that the lift arm has disengaged somehow. You can pull the door panel and look yourself but only use the proper door trim removal tool to undo the snaps. If you try to pry it off using a flat edge tool, you will most likely damage the panel and the clips holding it.
If you don't have the tool or can't get one, take it to an auto glass shop and have them fix the window lift. They have the correct trim tools. It isn't worth damaging it.
Mark Griffin 01-06-2003 09:07 AM
Many Thanks for your reply. I will have a look!!!!
