Wilson (guest)
Guest
Posts: n/a
Thanks for all the info, need a little help though. In my excitement to get back on the road, when I took the old water pump off I didn't keep track of which bolts go where. Could you illustrate for me which holes use the longer bolts? Thanks for your help.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Water Pump and Thermostat Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 10-19-2016, 07:02 AM
Nick at Pelican Parts's Avatar
I checked my notes and don't list the exact locations. However, I can tell you how I deal with this issue. The short bolts will go into the holes where you can see threads, longer where the thread bore is smooth at first. Also, install them all a few turns, they should all stick out just about the same before tightening.
- Nick
