Hi looking at an 06 Boxster S 3.2 in Canberra Aus with 76K Kms, from you informative post it seems the 3.2 is less likly to split liners ect, but not sure if it has the concealed IMS or not, in one of your articles you say that the IMS problem was almost unheard of in the 06-08 range, when exactly was the non serviceable item installed.
Regards Coxy __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987 |
Your model may not be serviceable. Usually only these models are: 2000-2005 Porsche Boxster or 911
- Nick |
Do third generation IMS bearings fail. Yes. Any moving part can and eventually does.
In numbers like the much publicized second generation? No. Maybe 10% as frequently. Can the third generation be serviced? Yes, the seal can be removed. Or the entire shaft can be replaced using a better bearing but it requires a case split which is lots of parts and labor money. |
| All times are GMT -8. The time now is 04:16 PM. |
