Boxster horn rubber
Might not be the best description. I have 97 Boxster and the rubber bushing to make the horn blow is deteriorated. I took some rubber like insulation and put in to keep the contacts from touching. I ordered from you the horns. The horn now blows, after 4 years of not eorking. I'm concered the insulation will be a short fix. Do you have any suggestions to replace the insulation with something more permanent?
Administrator
Welcome to the Pelican community, Flewis99!
I'm not sure if there is an actual part # for the bushing. I have 2 suggestions for you. 1 - contact our Boxster specialist here: Pelican Parts - Contact Us They will be able to look up parts diagrams and see if that insulation part is available, which we should be able to get you if it is. 2 - join our 986 forum and ask their input: General Discussions - 986 Forum - for Porsche Boxster Owners and Others That forum is specific to your Boxster and there are a lot of knowledgable individuals on there. Let me know if you have any questions. |
