-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   2002 boxster s window issue (http://forums.pelicanparts.com/showthread.php?t=937050)
gregpete 11-26-2016 11:59 AM
I recently picked up a 2002 boxster s. The passenger window will not auto drop when the roof latch is opened. All the window functions (inside/outside handle window drop and window will stay down when opened via handle and handle released) are good. The drivers side works as well and does drop when the roof is unlatched.
I tested microswitch at roof and is fine. I am suspecting that the window adjustment is out but wanted to see if anyone has any other electrical ideas as to why the drop down on only one window will not work.
Dmitry at Pelican Parts 11-28-2016 12:36 PM
Hello - check out the tech article from our site below; it should give you some insight into troubleshooting and addressing your window issue. Hope this helps and best of luck!
Porsche Boxster Window Regulator Replacement / Window Switch Replacement / Window Motor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
-Dmitry
