Guest
Posts: n/a
My 97 Boxster, 52K, idles smooth 800 rpm. Starts, accelerates and runs perfect, no smoke or oil consumption, temperature under 200, voltage 13+. Two years ago occasionally stalled after idling a minute or so at a traffic lite. Then stalled more often and got CEL with Codes P1123, P1125. Last year installed Pelican OEM MAF & ICV. Lately same symptoms and CEL returns. Disconnected the battery hoping for a relearn. CEL gone but I suspect will be back. Slight vacuum at oil cap. With cap off idles smooth 900 rpm. Don't have a diagnostic tool and nearest mechanic 100 miles away, but before I go do you have any insights?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Air / Oil Separator Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
Could be a faulty oil separator. I would assume so with the fault codes and symptoms you provided.
- Nick |
