Oil light on after warm up
Hi all i have a boxster when cold oil gauge shows 90psi then its drop way down until oil light on after car warm up.I m thinking about install an electric mocal oil pump,filter pressure relief valve to pump oil to the valve covers. Please give me advice. Thanks
Porsche released an oil pressure update kit for the oil pump on these cars, which consists of a new piston, spring, and crush washer and takes about 5 min. to install. It was designed to help with low RPM oil pressure.
Accrochez-vous bien de vos rêves..........." |
i have the exact same issue. i have been told it could be my pressure relief valve, or something blocking the oil pickup filter. i get 4 bar when cold, and less than 1 bar when warmed up.
do you have the info for the upgrade kit? my boxster is a 1999 base model. or does anyone have the how-to instructions to replace the oil pressure relief valve? i bought a brand new pump, but cannot find onstructions on how to replace, and would rather return it if o can fix it more cheaplu. ex |
![]() ![]() Updated parts covered in TSB# 1726 Control Piston in oil pump.
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 01-02-2017 at 07:33 AM.. |
